RX co do KL-ZE to znalazlem
0-4062: both closed
4062-4781: #1 open, #2 closed
4781-6812: both open
6812-fuel cut: both off
The KL03, by contrast, is:
0-3250: both closed
3250-4250: #1 open, #2 closed
4250-6250: both open
6250-fuel cut: both off
By using a KL03 computer with a KLZE engine, the VRIS points will not be correct, causing less-than-ideal output from the engine. A KLZE computer cannot be used with the KL03 VAF because they are calibrated differently. The best solution is to get the KL03 computer's VRIS points revised if you go to the KLZE.
http://www.geocities.com/viv95pgt/klze.html
nawet niewiedzialem ze sa 3 rodzaje kolektora(long, short , Curved)
